Towing A Hudson with the OD
The Hudson manual says" ... before towing pull the OD cable all the way out ."0
If towing a considerable distance I would recommend removing the drive shaft.Geoff0
Oldfarmer1947gmailcom said:The Hudson manual says" ... before towing pull the OD cable all the way out ."
Thanks, I still haven't found any reference in the owners or service manual and went thru 2 pages of search results here?0 -
I just checked 1st owner's manual I came to http://www.hudsonterraplane.com/tech/1953/JetLinerOwnersManual.pdf The posted text was from this volume0
If it is a Jet, you will lose some transmission oil with the drive shaft out, but that is better than wearing out the needle rollers and output shaft, etc.0
Oldfarmer1947gmailcom said:I just checked 1st owner's manual I came to http://www.hudsonterraplane.com/tech/1953/JetLinerOwnersManual.pdf The posted text was from this volume
Thanks,
That explains it. I was reading my 49 owners manual.
Thanks Ken............0
Tow it so the front wheels are on the ground, not the rears. Tie the steering wheel tight to the door frame.I have towed numerous Rear Wheel Drive cars this way, once a Rear Wheel Drive Toyota Corona station wagon fully loaded with stuff all the way from California to Florida. No problem at all.0
