Rear main seal replacement
im sure you will figure a method...Cherry picker would work but perhaps put long bolts in back of motor plate then chain to each side, or bolts in crank then chain across to each frame rail to hold. Be sure to use Dap Permatex black RTV in corners of seal and maybe rotate Seal slightly so gaps not near corners of cap
I held the engine up by bolting a piece of heavy steel on each side of block to act as legs,worked great.The vertical pieces had a foot on the bottom to sit nice and flat on the floor.0
I like the legs....safe and effective.0
Why not just lift the engine out of the car? A lot easier to work on and no risk of instant death, crushed under 700 lbs of cast iron!
had the same thing happen as ken did i tryed 3 time i have 3 seals for sale with only 5 or 6 miles on them. rope seal 1 time0
Gosh, They may have had a bad run on those seals because Ive put them in 4 or 5 motors including 2 race motors since someone posted on the old Forum to use 318 Mopar Neopreme rear Seals a number of years ago. Maybe I just got lucky or maybe their going to drip eventually... .
Chuck, you're just "livin' right!"0
Oh Keith, I dont know about 'that' but recall putting a lot of black Permatex RTV in the groove & cap just to be safe....Hopefully filled the gap....keithfullmeryahoocom said:Chuck, you're just "livin' right!"
I'm with Ken.......replacing a main seal "on the bench" during assembly isn't a tough job, but you only want to do it once and do it when it's easy. It's a costly, time consuming pain in the rear (main, that is) to change it after the fact. I've used the old rope/woven style since I was a kid, with no issues. The one used in the splashers is the easiest.
F
Strange--I've not had a problem with the motors i have done.
Randy
Ken, I had a leak on my latest 56-308 engine and it looked like it was the upper part of the lip type seal but, after cleaning the backing plate very good it was not the seal.
The upper long mounting flywheel bolt that threads into the back of the block and protrudes in the rear valve train was leaking oil down the threads and between the rear spacer plate.
I removed the bolt and put lots of black RTV on the threads and no more oil leak. ( I knew this could be a leak problem when I assembled it but over looked anyway) Rudy B.
