1941 hudson parts for sale
bigd65
Hi, I have up for sale most of the frt suspension ( hubs, spindles, control arms, steering linkage, steering gear), complete engine and transmission, with overdrive. The vehicle was last driven about 8 years ago, and supposedly had a slight knock. The Transmission overdrive has had the back housing taken off and The rollers have come out of the cage, but appears to be all there. Will shortly have the complete rear differential also. The parts are from a 1941 Hudson 2dr sedan. I believe it is a traveler model? I also have a new brake hose set, and two distributor caps, one with rotor and points and condenser. I have a owners manual not sure if original, and a service manual that I am pretty sure is a reproduction. You can contact me at 701-320-1317 or email djkapp@daktel.com. Thanks, Dan
You might want to mention your location.
sorry about that, it was a little late when I wrote this up. I am located in North Dakota. The transmission and overdrive have been spoken for already
- 97 Essex Super 6
