6v to 12v OD solenoid conversion
Kerry check your email. It's all there.0
disregard
I think he's asking about the solenoid mounted to the overdrive unit on the transmission.
I have read that the 57 Chevy solenoid will work? Probably most 12v borg warner units will work?
Google Borg Warner overdrive. There's a company in CA that sells a 12v solenoid that is designed for Borg Warner overdrives for $300. I bought one and I couldn't get it to work. I returned it when I figured out the original solenoid worked by using a voltage reducer.....0
Yes, I am talking about the OD solenoid that bolts into the OD transmission.
Ken Cates suggested a Studebaker 12v solenoid as they used the BorgWarner od as well.
Studebaker International has new ones-
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50001003a~Z5Z5Z5AAGBS~P175.00~~~~S4HW0G2S1N98182415430b~Z5Z5Z5~Z5Z5Z50001003a
SI doesn't have any in stock.
Just talked with Northwest Transmission parts and they will re-wire a 6v OD solenoid to 12V.
Northwest Transmission Parts
13500 US Highway 62
Winchester, Ohio 45697
Telephone:
937-442-2811
