Hood trim 46 truck.- Bench seat
pivotpro
looking for the 3 pieces of trim and the "Hudson" emblem on the leading edge of the hood.
Are there any more bench seats still out there? Every one Ive seen in pics is rusted out wire..
Thanks
Brad
Use a clapped out seat spring set from a stepdown and build your own frame.0
I might have some seats out of a 54 wasp you could possibly use. Seems like it would require quite a bit of cutting down.
Thanks! Scott0 -
I would think a Ford frontier, Toyota Tacoma or a Chevy S10 would be close0
'84 Jeep Cherokee front buckets would work very well, and because of the more compact design you'd most likely end up with slightly more leg room
used to be the mid 1980's ford ranger pickup was the hot ticket!!0
I have an early'mid 80's Chevy S10 (or S15) Seat and Belts in my Truck. It practically bolted in place and the back flips forward to store things behind.
- 97 Essex Super 6
