Wheel Trim Ring trivia
I found that the new trim rings that Dale Cooper sells are beautiful! One little glitch though.... The partial hole for the valve stem was not large enough for my valve stem. I think It's due to tubeless tire stems. They are larger in diameter than the tube type. My old original trim rings fit just fine. I'll figure out how to enlarge the relief without damaging the ring... I hope,...
They fit my convertible 5 1/2 inch wheels pretty good but not the standard 5" width wheel. The valve stem is not the problem.
