valve train parts '35 splasher
There was normally only one. Probably someone trying to compensate for springs losing pressure, but why only intake?0
geoff, thank you. the second piece is actually a ring..looks like it is serrated..to rotate the valve??? i don't know. i will delete from the reassembly. thank you. regards, tom
i forgot to mention it is a 212 cu. in. 6 cyl..but you probably already figured that out.0
