Parting out a couple of 54 Hornets
ski4life65
The city I live in is giving me a hard time about the Hudsons I have in my field, so I need to find them a new home. I have a pair of 54 sedans I am parting out before I haul the skeletons off. Any requests for parts.......really cheap! No power steering, gas tanks, glass or motor/trans left, but mostly everything else is available. I am in Denver, but willing to ship.
Don
Don
Hi Don,
Do you have the 54' grill, front turn signals, front bumper, headlight trim bezels, passenger side door handle, and steering wheel horn?
I think that is all I am missing.
Christopher.0 -
Christopher
Sent you a PM0 -
Hi Don, are the rear outer frame perimeters any good?. Are you planning on attending the Big Country regional?. Mail me back,thanks Doug0
If we don't get too much snow tonight, I will take pictures of the cars and post them. There is some rust around the wheel wells of both of them, but I never looked underneath to see how far it goes. I am also parting a 51 that is really solid.......I was going to cut out the entire rear perimeter frame of that car. I wasn't planning on going to Big Country, but I am sure there are a few guys headed that way from our chapter that could deliver stuff.
The city recently changed the zoning in my area from agricultural to residential, and now I have to clear out all the my cars, or get them registered and drivable. I was able to get a few of them running, but 6 of them needed to go. I sold one complete car so far, and Dick Bell has an interest in another one.......4 more to go.0 -
Don,
What are the body styles of the 6 including the one that sold? Just wondering.
All sedans.0
I forgot to ask about the years of all 6. Any 48/49's?0
51 and 540
Don, I need a gas cap and an oil dip stick. Any luck? I could also use the plastic ring that goes with the antena base under the plastic ball that rotates the antena. Let me know-no need to play in the snow for these but they would be helpful.0
I definitely have a dip stick. I will check on the others.0
Some 54's that had power brakes have a longer dip stick along with a long tube.0
Rear hood body latch , the owner before me welder a pice of threaded penciel rod into a loop.0
I need the passenger side defroster vent that is of stamped metal( under dash), to complete my heater re-hab?????? Texas..Also the springs in my wiper blades arms are needed? Carpet hold down strips for the sides?0
I will start pulling parts of this weekend. I should be able to take care of most requests.
Email me please. Apparently the pm's aren't working. My address is arkiejazzGRUMPY@aol.com and drop the grumpy0
to bad you don't have any 48-50 tail lights or a better geared rear end.....0
Chuck,
The 54 has a Dana rear end, and you can put any gears in it as they are still available.0 -
Don, could you save me a drivers-side sun visor if there are any? Thanks.0
I need a complete set of front door hinges, both sides..any year step down.0
Hi Don,
I need some cores. I need both rear center bumpers, the inside sun-visor brackets, front door vent window frames. You can email me a GMC46golden@aol.com. Thanks, Glen0 -
You can E-mail me also @ hotrodman2010@hotmail.com.
I tried to e-mail you but it did not go through?0 -
Don, do you have an exhaust manifold for 308, I need one to mount the 7x adapter for dual exhaust.
Thanks
Mike0 -
It's fairly easy to make a single carb unit work . The only real difference is the dual stove pipes for the chokes .
Roger0 -
The adapter measures about 4 1/4 inches from center to center on the widest part, on my exhaust manifold measures about 3 3/4 inches at the widest part0
Yours may be from a Nash bodied car ,hose manifolds were slightly different,
Roger0 -
Thanks for the help, looks like I need to start looking for a hudson manifold.
Mike0 -
Don, How did the disassembly process go?0
Were either cars equipped with power brakes. If so, do you have the vacuum tank?0
1 has power brakes but tank was missing when I got it0
Any of the vacuum tank fittings left?0
