hudson 8 valve lash ?
I'd suggest sending an email to Dr. Doug at Wildrick Restorations Address is on his website.
Kim0 -
.008" inlet and .010 exhaust, with engine hot.0
Make sure you use a new gauge after you set 4 valves for then they are pounded out of shape and you will have tight valves. Best way is cold set at 12 and 14. Walt.0
