Fuel Sending Unit Float Arm
[Deleted User]
edited October 2012 in HUDSON
Does anyone out in Hudsonland have some advice on the correct way to bend the float arm on a fuel sending unit. I purchased a unit for a '49 Ford F1 Pickup that has the same screw pattern. This is going in my '50 Commodore Six. The float arm is straight and I know that a Hudson float arm has several bends in it. I have nothing to compare it to as the original sending unit was removed from the tank by the previous owner. Any thoughts?
Glenn Degere
  • dave s
    dave s Senior Contributor, Moderator
    edited October 2012
    if you state where you are located, I'm sure there is someone near who has an original unit you can comare it to.
  • hoggyrubber
    hoggyrubber Expert Adviser
    i have the tank and sending unit out of my 53 hornet. i can take a picture on monday if it will help you. i will be out of the saddle on sat, i have to work a another double shift 17 hours straight thru.
  • 53jetman
    53jetman Senior Contributor
    Here are some pictures of a NOS sending unit I have in stock - four views
