Rear sway bar hornet
[Deleted User]
edited August 2012 in HUDSON
I can almost answer my own question but here I go... I had the hornet jacked up and I finally concluded after noticing it a hundred time my rear sway bar is bent like the letter S. I have never been under any other Hornet so I'm asking this can't be rigth .. The car handles good on the high way but I can't see it helping.....
The part is support be be straight rigth ...If so if I removed heated and straighted I can't see this meeting spec.... Hersey here I come ......
  • ski4life65
    ski4life65 Expert Adviser
    Every one I have seen is "S-shaped". I think you are good
  • SuperDave
    SuperDave Senior Contributor
    Leave it alone! It's a Panhard Bar that keeps the rear end centered in the car. Just make sure the bushings are good. Another one of Hudson's "over" engineering..
  • Thanks guys
