Stepdown Overdrive Kick-down
ernie28
ernie28 Expert Adviser
edited August 2012 in HUDSON
I am having difficulty with the overdrive kick-down of the Pacemaker. In all other aspects (that I am aware of), the overdrive is working well - the control knob engages and disengages, it drops into overdirve at the correct speed and can drop down again at the low speed BUT the kickdown switch function is not working. I have tested the switch and it tests out OK as per the manual.
My question is, apart from the kick-down switch and harness to it, are there any other components of the the overdrive that could cause the kick-down function not to work if all else is operating OK?
  • What happens when you hit the switch? does the motor "Jerk" . If it does the switch and wires are good. If not and you checked the switch out all it leaves isa bad wire.
    The switch actualy kills the ignition momentarily -hence the "Jerk". That is what allows the unit to drop out.
    Roger
  • Park_W
    Park_W Senior Contributor
    edited August 2012
    In the OD solenoid is a set of contacts that are closed when OD is engaged. They're part of the kickdown circuit, and they are what provides a temporary ground for the ignition when you hit the kickdown switch. Sometimes these contacts get out of position or get oil on them and don't make electrical contact, so the ignition doesn't get grounded and the OD doesn't kick out. For a quick check to see if this is the source of the problem, use a test light, with one side powered from the battery or ignition and the other connected to the smaller terminal on the solenoid (you can leave the regular wire to that terminal hanging loose). With OD button pushed in, drive the car and as soon as you get above normal OD cut-in speed you should see the light come on. If it does, then the ignition grounding part of the solenoid is OK. If the light doesn't come on above cut-in speed, you've found the problem. Back to the garage.
    Remove the wires from the solenoid so you can remove the solenoid cover. The grounding contacts are the very obvious ones just beneath the cover ... the "movable" contact is at the end of a curved, flat piece of black-colored spring steel. First, wipe the contacts with a paper towel or other dry material, being careful that no debris gets left between the contacts. Then, with the OD button pushed in, use a hot wire from the battery to the larger terminal on the solenoid so it energizes, then look at these contacts to see if they're definitely closed. If not, de-energize the solenoid and carefully bend the curved "strap" a little so the contacts are a bit closer together, then run the test again to be aure they're definitely closing. De-energise the solenoid and be sure the contacts are now open. Then reassemble and drive-test to see if the kickdown problem's gone.
  • ernie28
    Many thanks for your pointers guys.
    I will be spending some time this weekend re-checking the harness - I remade a complete harness but there may well be an issue causing the problem and if all is good there I will check the solenoid as Park suggests.
    I will advise the outcome.
  • ernie28
    Eureka! It was a faulty connection on the wire from the K/D switch to the coil. Repaired, tested and road tested and it all works like a charm. I am pleased there were no issues with the solenoid or other components. One more job off the to-do list. :)
    Thanks again guys.
  • Good deal . . . Simple repairs are the best,
    Roger
