Lube Question
drivergo2
drivergo2 Expert Adviser
edited August 2012 in HUDSON
What to pour in the cylinders before trying to turn the engine over by that i mean trans fluid ? pb blaster? both together any sugg.? 52 308 Not run in 40 years plus. Thanks John
  • hoggyrubber
    hoggyrubber Expert Adviser
    it was suggested to me to pull oil pan and clean out crude first, which i did. but even with that i never could get 2 valves unstuck without pulling head and the rings without pulling pistons. i have heard good things about kroil or acetone/atf mix. good luck!
  • Marconi
    Marconi Senior Contributor
    I've had great sucess with Kroil.
