Seeking 1936 juice brakes
A fellow 1934 Hudson owner in Austria is in the process of restoring his convertible and asked for our help in locating '36 or later brakes to convert from the cable brake system to hydrolics. Park W. offered my a complete '36 brake set-up years ago (which I didn't take) however, wondering if anyone building a rod might be willing to part with the 36 or later original brake stuff.
Let me know and I will put you in touch with the gentleman.
Jim
Jim
Jim, I'm just going through the cable to hydraulic exercise with our '35 H8 roadster. FWIW the more readily obtainable (and larger) stepdown brakes can be fitted as well as the '36 etc brakes. The stepdown backplates bolt straight up to the '35 and presumably also the '34 stub axles, and with a little bearing swapping the stepdown hubs will mount onto the '35 spindles.0
Jim, Old Fogey in the UK has those brake parts. He's not used them, so may be willing to sell.
PW0 -
Thank you Bob & Park. I will pass info along!
Jim0 -
Hey David, I will let Kurt know you still have these parts. He is located in Austria (NOT Australia!) however, the '34H is being restored in Belgium so, relatively close to you in the UK.
I will private email both of you later so you can decide the best course of action.
Will we see you @ Gettysburg this year? Hope so!
Jim0 -
Thought this thread was about the H8 conv. I used to own!. Having now aquired back a '35 Terraplane coupe with later engine/trans change I too am looking for options to convert to hydraulics. Going with different rear axle and will adapt whatever I decide on using to make fit on the front beam (possibly Jag xj6) so really looking for info on a pedal box that will fit fairly easy , doesnt have to have power but will need a decent master cylinder for at least discs on the front. I'm thinking floor mount type as I'm now with a cable clutch set up which for visual appearance needs to stay in a low position.BTW this is a LHD vehicle, any parts leads help/advice much appreciated on either the pedal box or front brake set up0
