1932 body/ firewall tag wanted
32huson
Wanted an identification tag from the firewall/body of a 1932 essex terraplane for my cpoupe. Tag with serial number between 350000 and 364125 needed.
K-Gap sells a very nice repro Serial Number/Patent Plate that mounts on the firewall w/ 4 slotted pan-head screws (No Rivets!) for the 33-36 Hudsons & Terraplanes. I'm not sure of the exact difference between the '32 plate and the one used in '33. You would need to check. If this is for a rod, you should be OK w/ the later plate.
Hint... if you do buy a new blank plate from K-Gap, take it to one of those "Things Remembered" stores at your local mall and have the SN & Model Number engraved rather than stamping it with a set of dies. I know... not exactly original, but a much cleaner look.
The G-Kap PN for the 33-36 plate is 382, price back in 2007 was $20.00.
Good luck.0 -
BTT I still looking for an original 1932 serial plate.0
btt0
btt Still needing an original serial number tag0
Bumping this old post to the top for those who have not seen it before. I am still in need of the body serial number tag for my coupe project.0 -
I believe this is about the vilest-looking rod I have ever seen. I have 34 and 35's and the firewall plates, if similar to the 32, would look good on this machine. But you could create your own with the features you like - then just make it cruddy and nasty. Good luck.0
Thanks Grebus. I think Iwill keep looking for the correct year tag and number.0
I see this thread started in April, so I suspect if one were going to materialize, it would have by now.
There's a fairly limited number of folks who follow this board, compared to the overall membership in the HET club. The logical next step is a wanted ad in the White Triangle News, which has a much larger circulation. Why don't you send me an email- mmittge at compprime dot com, and I'll tell you how to place the ad. I don't seem to have very good luck with the mailing system on this board.
What engine is in your coupe? Looks like an Olds, from what I could see.0 -
The motor is a small block chevy. Email sent.0
- 97 Essex Super 6
