Gearbox mounting rubber for 48 Hudson Super Six
I was looking at Steele Rubber products stuff I believe and saw where they will put new rubber on your old steel.
http://stores.ebay.com/Steele-Rubber-Products
KGap carried them but you might check with them before you order. I'm still waiting with no word...several months now.
Maybe Bill and Charlie's on eBay0 -
Steering boxes are not mounted in rubber, they bolt directly to the frame. More info is needed on this item?? Walt.0
walts garage-53 wrote:Steering boxes are not mounted in rubber, they bolt directly to the frame. More info is needed on this item?? Walt.
Hi Walt
He's looking for a new gearbox mounting rubber for a 48 Hudson. Do you know a source?
Thanks0 -
Is it a transmision mount.?:unsure: John0
Dave, these Americans cannot distinguish between a "gearbox" as we colonials call it, and a steering box. What we call a gearbox is a transmission to them. I can get a suitable alternative here for around $100. It is a generic type which can be modified to suit. I used one on Trevor's '37 T coupe.
Geoff0 -
Thanks Geoff.
I'll give Andrew Peterson in Papamoa your details then & you 2 can talk without me in the middle
Dave0
